Is there a way to update the list of STB's in the controller?
//Bo.A long list...
You can by having the STB chip replaced. You can view HERE the STB's supported.
The STB-C controller has a replaceable chip as shown below
Regards Keith....
Where do I get the chip? From a dealer?
How can I identify which version I have?
You will need to purchase the chip from a dealer who would normally install it for you as well with a cost.
Whilst you can identify the table version by looking at the currently installed chip, its almost impossible without the STB-C removing it from the TV. Below is a picture showing a STB-C chip with its markings.
You can also check the Software and Table versions via the Service Menu as follows:-
Surely, the only reason to change the chip is because you wish to control a STB which is not available with the currently installed chip ?
So, which Set Top Boxes do you wish to control ?
Thanks for the info Keth!
Keith Saunders:You can also check the Software and Table versions via the Service Menu as follows
Keith Saunders:So, which Set Top Boxes do you wish to control ?
