hello,
i received a pair of h6 headphones for christmas. they are excellent.
what is missing is a way to protect them while on the move. the cloth sack will keep the dust off, but i would not put them in my backpack...
has anyone found any great ideas, thanks for your feedback !
- scott
Scott,
B&O does offer an optional H6 headphone leather bag. Suggest you talk to your dealer..
Regards Keith....
"Headphone Mate Ultra" or "Slappa Pro HardBody" (unfortunate name but check out the reviews on youtube) both make hard shell cases for larger over the ear headphones and would suit H6's. The problem I find with such cases is the physical room they take up in my bag or a pain to carry as a solo item and my case ends up at home always (I bought the WACKS for my Parrot Zicks which can also house my H6's or Form's)
Over many years of using headphones the best and safest place I find to keep them is around my neck; I know it can be a pain at times but they are ready to be used, out of the way to a degree, in a environmentally safe place and I know where they are.
I personally find the most headphone damage happens at home, i.e. you inquisitive children and or all kept in the same draw with other headphones, cables etc.
If I'm going into a hostile environment i.e. on holiday then I take my "in ears" as they take up less bag room and weight.
http://www.mygocase.com/products/f-type-headphone-case
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
