Lighting control question
This post has 2 Replies | 2 Followers
Razlaw
Posts 4,345
Razlaw Posted: Tue, Jan 21 2014 6:05 PM
I have a security system that uses Z WAVE devices. Through it I can control lights, security system, and video cameras from my iPhone and iPad. There is a remote available for the system to control the lights without accessing the App. It appears it is the standard remote that can be purchased to control the lights directly. I also have some Philips Hue lights.
Is there anyway to gain control of either or both sets of lights with a Beo 4? I am thinking there is not, but I certainly could be wrong.
Thanks!
Alex
Posts 46
Alex replied on Wed, Jan 22 2014 5:34 AM
Technically yes but the better question is does it involve the investment of your/your dealer's time?
There are ZWave/RS232 Interfaces that can be programmed as ML Gateway custom 232 drivers.  It would be A LOT of work for VERY little payoff.  Almost better to just change your lighting system to RadioRA2.
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 22 2014 1:29 PM
Thank you very much. I sounds like too much work for the amount of benefit. Again, many thanks.
Page 1 of 1 (3 items) | RSS
