BM900 repair - fixing aerial coils
Duncan Jones
Melbourne, Australia
Posts 16
Duncan Jones Posted: Wed, Jan 22 2014 1:07 AM
Does anyone have best practice pointers on how to repair broken connections on these very fine copper wired aerial coils....??
As a result of breaks, the wires do not reach the original soldering points on the PCB anymore. Do I try to unwind more wire from the coil or solder in a make-up length of wire to reconnect to the PCB or completely replace the coils with new ones....??
Any help appreciated.
Regards,
Duncan
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Jan 22 2014 7:03 AM
In my opinion a repair attempt is always worth trying before eventually replacing.
If a piece of copper wire (cut component lead or similar) is what's needed to extend the remains, I'm sure it will be fine.
I would not recommend unwinding the coil. You will most likely be facing a labor intensive job of realigning if you do.
essence
Posts 23
essence replied on Wed, Feb 5 2014 8:16 AM
On the rear of the chassis is the B&O logo and model number, and sockets to connect accessories including a record and tape player and external loudspeakers. A white electrical cord and plug extends from the rear of the casing. 4 rubber feet elevate the radio from the surface on which it is positioned. The radio casing is closed with 2 screws. Inside the casing, there is a dual-channel audio amplifier for reproduction of stereo gramophone records that deliver 2 × 5 watts of undistorted power output. The radio is prepared for single transmitter broadcasts, and has a B&O multiplex adaptor (stereo decoder). Hope this helps.
Killmouski
A hot tin roof in Stockholm
Posts 55
essence:
On the rear of the chassis is the B&O logo and model number, and blah bla blah ....
 Hope this helps.
Im sure it helps a bunch telling the op that there is a power cord and a b&o logo
at the back of his radio and wouldnt you think that he found out about
the number of screws long before he ran into the coil problem?
Page 1 of 1 (4 items) | RSS
