Control my Sony KDL-60LX900
Roger_NO
Posts 6
Roger_NO Posted: Thu, Jan 23 2014 6:49 PM
I am new ti B&O and wonder if it is possible co control my Sony KDL-60LX900 with a Beo6 remote?
I also want to control an Apple TV.
What do I need to do?
Is it possible to do with a Beo4 as well?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
A Very Warm Welcome to Beoworld.
I can confirm that the Beo6 remote will DIRECTLY control your Sony and Apple TV once programmed.
I am assuming from your posting that you do not have a BeoVision TV ? other wise they can be controlled using the PUC in the TV
If you have a BeoVision TV, then the Beo4 can control 3rd party products such as the Sony and Apple TV where the PUC acts effectively as an IR converter.
Regards Keith....
Roger_NO
Posts 6
Roger_NO replied on Thu, Jan 23 2014 7:04 PM
I do not have a BeoVision, and what I wish to do is the following:
- Be able to control my Sony TV
- Be able to change channels on a Thomson DTV box when watching TV
- Be able to control my Apple TV, and when watching Apple TV control the volume on a PlayMaker (as I use AirPlay to send the sound to my BeoLab18).
Is all this possible with a Beo6?
Roger_NO
Posts 6
Roger_NO replied on Fri, Jan 24 2014 10:43 AM
I have discovered the iPad App, and I think I will be able to make the macros.
But I really need help to find/create the XML files for my Sony 60LX900 and Thomson DBI-8500E Set Top box...
Anybody?
Page 1 of 1 (4 items) | RSS
