Over the last few weeks N Radio has been dropping out every few minutes. We had fibre broadband fitted a few months back and all has been well. I have been trying to eliminate the problem but no luck so far any thoughts would be appreciated.
What i have tried so far:
Increased buffering to max - no different:
Beosound 5 shows network connection during drop out - yes
Spotifys streams perfectly - Yes
Change radio station - still drops out
Network connection dropping - not what i can see.
Latest version of SW - Yes
Thanks in advance
Most likely not an issue on your side but rather on the streaming source. So try to access the specific radio stations stream via their own home page directly from any of the PC or Macs that you might have at home; might just be that the source has too many connections and not bandwidth enough. So text also the same station during various times to see if the same issue occurs.
Thanks for the suggestion i tried that, streaming from the website is good no drop outs on the same wired network.
When it drops out and i select a different station it connects straight away, when i go back and select the original it reconnects straight away.
If it drops and i leave it the dropout is over 30 seconds.
