Can my beo2300 be set up to play music wirelessly or with bluetooth?
This post has 20 Replies | 1 Follower
Edhusky
Blaine WA
Posts 9
Edhusky Posted: Sun, Jan 26 2014 10:26 PM
Hi, I have always loved my beo2300, but no longer play cd's as much. Is there a way to stream music to it wirelessly or through bluetooth from my iPhone or iPad ?  I would like to use it, but now it is just sitting around not being used.  Thanks for anyone's help.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Jan 26 2014 10:43 PM
Stream from a web radio or iPad etc using a suitable cable with DIN connection to your tape input socket.
Steve at Sounds Heavenly (bottom of forum page ad.) can probably make up a cable for you.
Graham
Edit
Or connect an Airport Express or similar for wireless connection. Connect the Beomaster and web radio or Aiport Express to a socket extension controllable by a remote control so that you do not switch off the streaming device and leave the Beomaster switched on.
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Sun, Jan 26 2014 11:46 PM
And if you really want to do this wirelessly then you could connect an Apple AirPort Express to the tape input socket of your BS2300 (or a bluetooth receiver, but bluetooth audio is not very high quality)
Martin.
pacificocean
Posts 100
Or a playmaker to keep it B&O.
lano
Posts 161
lano replied on Mon, Jan 27 2014 5:35 AM
Or a Sonos connect to the AUX input...
Millemissen
Flensborg, Denmark
Posts 14,680
Or....how about the Essence-box?
Edhusky
Blaine WA
Posts 9
Edhusky replied on Mon, Jan 27 2014 3:24 PM
Thank you all for your suggestions, but I'm not sure how to connect my wireless connection (non airport express) router to the beo2300?  You say " to a socket extension controllable by a remote control", but I'm not sure how to accomplish this. Could you please provide some detail or examples?  Are the replies to my questions suggesting I have to connect the beo2300 to my wireless router?
Edhusky
Blaine WA
Posts 9
Edhusky replied on Mon, Jan 27 2014 3:25 PM
What do you mean by a "playmaker" ?  Sorry, but I seem to be a novice at this.
Millemissen
Flensborg, Denmark
Posts 14,680
http://www.bang-olufsen.com/en/sound/sound-systems/playmaker
It can be used with the 2300 through the AUX-in as well.
MØn
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Jan 27 2014 5:49 PM
Edhusky:
Pretty much all of the solutions suggested are a box which you would connect to your BS2300 via the tape/aux input on the BS2300. It is then this box that connects to your wireless router (wirelessly) and your iphone/ipad then streams to this box via the wireless network.
Hope this makes sense.
Martin.
Edhusky
Blaine WA
Posts 9
Edhusky replied on Mon, Jan 27 2014 5:55 PM
Hi Martin, and this box would be ( make model number, name of)?  (Sorry for being so dense), but THANK You for this help
TWG
Posts 1,672
TWG replied on Mon, Jan 27 2014 6:23 PM
For Bluetooth I can suggest the very nice Nokia MD-310, see pictures of it in this thread:
http://archivedforum2.beoworld.org/forums/p/3408/68262.aspx#68262
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Mon, Jan 27 2014 6:24 PM
Any of the boxes suggested above, eg Apple Airport express, B&O Playmaker, etc.
So for example, you could plug a Playmaker (or any of the other options) into the BS2300, the playmaker will connect to your wireless router (wirelessly), and your ipad will stream music to the playmaker (which will then send it into the aux in of your BS2300 via the cable connecting the two)
Martin.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jan 28 2014 1:45 AM
I just can't see the point of a Playmaker for what you need. An Apple Airport Express is ideal. It's only $99. Then, for just about $16.00 you can purchase the BeoPlayer app for the iPad or iPhone. This gives you a very "B&O" interface to send music from your iTunes library from your computer (complete with cover art) as well as the same internet radio stations that you would find on the BeoSound 5.
Chaka
Chicago
Posts 312
Chaka replied on Tue, Jan 28 2014 1:05 PM
Try this -
eBay item number:
201027134051
Not sure how good they are, but they offer money back if not satisfied.
Saw it today on ebay.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Tue, Jan 28 2014 4:06 PM
beojeff:
The reason would be sound quality...the Airport has some fairly severe limitations with respect to not only the DAC ts uses but the analog output circuitry that drives the analog sound outputs. The Playmaker DAC seems to sound as good as any I've heard. I haven't blind tested it or such but I find nothing to notice about its sound, it seems transparent. Can't say the thing about the Airports I've heard, though they can be setup to drive an outboard DAC easily enough, and you don't need that expensive a DAC, which makes me think a lot of the sonic issues are due to the analog circuitry and power supply in the Airport.
You could get an Airport, and a cheap DAC, and still come out cheaper than the Playmaker I think, if money is an issue.
Jeff
Millemissen
Flensborg, Denmark
Posts 14,680
Something like this:
http://www.amazon.com/FiiO-Digital-Analog-Audio-Converter/dp/B005PWPUW6/ref=sr_1_2?ie=UTF8&qid=1390929423&sr=8-2&keywords=Dac
Probably you could even 'power-feed' it through the usb-port of the AirPortExpress.
Simonbeo
Posts 1,451
Simonbeo replied on Tue, Jan 28 2014 6:12 PM
So what is the benefit of the B&O product over the Apple wireless device?
whoops!
just saw the answer.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
vikinger
Posts 5,422
vikinger replied on Tue, Jan 28 2014 9:41 PM
Edhusky:
There are several extension lead sockets available in the UK that have an IR sensor that is intended to power-off your TV completely rather than leave the TV on standby: you tune the sensor to pick up your TV's remote ON/OFF command, and the socket will power off a few seconds after the TV shuts down. None of this is advisable with a B&O TV though (see separate thread on that topic) but it's useful if your web radio or streaming device has a remote control because you can make sure that your Beomaster switches off automatically when you power down the streaming device. Otherwise there is a risk that you switch off the net radio but leave the Beomaster on.
Graham
Edhusky
Blaine WA
Posts 9
Edhusky replied on Wed, Jan 29 2014 3:34 PM
Hi, what cables would you recommend from the beo2300 to the apple airport express? Would a din-7 to 3.5 audio jack work without any degradation in sound or do I connect it to the USB or Ethernet port on the airport express?  I've been only able to find cables from din-7 to female rca, but no male rca to either ethernet or USB.
Greatly appreciate any suggestions. Thanks
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Jan 29 2014 4:53 PM
Check out one of the sponsors' website: http://www.soundsheavenly.co.uk/bando-ipod.htm
Ralf
Page 1 of 1 (21 items) | RSS
