Don't know whether anyone else has experienced this issue, but since the last software update (which came up on my TV a few days ago) I cannot get the webmedia home page to load. The TV just says that a network connection is not available even when I know that everything else on the broadband router is working.
However, if I select YouTube or Spotify in the main menu then they load and work without a problem. Has anyone else had the same problem?
Graham
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
This morning the webmedia homepage was available again.
Maybe corrupted software was reloaded/ replaced overnight. So my next question is this: if there is a break when the TV is updating its software so that the software is corrupted or incomplete can you force the TV to download the software again manually? Yesterday when I had the webmedia fault, checking the software simply produced a statement that the TV had the latest version of the software. There didn't seem to be an obvious way of making the TV download the software again.
Mine works to again
