When I want to use a Smiley in a post I just get an empty Smiley box to choose from.
I'm using IE11 and Windows 8.1
Regards Graham
It's a problem with IE11, I have the same on Win7. They work fine with Chrome.
Ban boring signatures!
No matter. I don't often use smileys and I'm not about to change my browser after using IE since it first started.
They don't work on iPads using iO7 either.
The best smiley on the previous forum just came up by typing []. Those were the days....
Graham
I'll have a look into this.
Lee
vikinguk:They don't work on iPads using iO7 either. The best smiley on the previous forum just came up by typing []. Those were the days.... Graham
BeoNut since '75
elephant:iOS 7 on phone with bbcodes :D and B and Y Works ? The Essence of B&O is discretion in design and life
elephant:Yes ! Now iOS 7 on iPad (mini) bbcodes 6 and C bbcodes are when you enclose the characters with [ and ] The Essence of B&O is discretion in design and life
elephant:Worked again What does NOT work is quoting a passage that was posted with bbcodes - then they just disappear .... The Essence of B&O is discretion in design and life
elephant: elephant: Worked again What does NOT work is quoting a passage that was posted with bbcodes - then they just disappear .... The Essence of B&O is discretion in design and life Also nested quotes don't work - the past 4 posts have been attempts to quote quotes
Worked again
Well they seemed to work. The question is, what do they look like on non- iPads?
The thread refers to 'Smileys', not 'similes'...
x:________________________
Jonathan: The thread refers to 'Smileys', not 'similes'...
Yes, but essence wasn't aware of this when he copied his post from here :
http://examples.yourdictionary.com/examples-of-similes.html
vikinger: Well they seemed to work. The question is, what do they look like on non- iPads? Graham
Better!!
Puncher: vikinger: Well they seemed to work. The question is, what do they look like on non- iPads? Graham Better!!
Smart *rse!
Puncher: Jonathan: The thread refers to 'Smileys', not 'similes'...
Tragically funny.
Oh wait, that is an oxymoron.
Wait. Is that a personification?
