Beosystem 4
This post has 2 Replies | 3 Followers
kai
Posts 362
kai Posted: Fri, Jan 31 2014 11:13 PM
Is it worth while upgrading from beosystem 3 to a 4. At this moment have beosystem 3 with Lab 5 lab9 and centre spk plus bs9000 and beosound 5 plus jvc projector and 100" screen all working great is there any reason to upgrade
Millemissen
Flensborg, Denmark
Posts 14,680
If things are working great - I would say: no - and yes!
You really should explore, if the new possibilities of the Sys4 - especially the sound management - 'True Image' - is enough for a change. It - indeed - is a great improvement.
The SmartTV function ('WebMedia')  probably won't be worth it (at least not as it is now). For some people the 'Home Media' is a very nice feature. Spotify - well, you can have Spotify with a much more fluent interface through a iPad/ATV-combo (if you need it on the BV at all). The same goes for Youtube.
The online installing of new PUC-codes is great - everybody agrees on that. And the auto-update function of the system might over time be a game changer - who knows what will be added in the future Smile
BUT - you will have to buy the NL/ML converter for the integration with your BS5 AND you will have to add optional hardware and software to keep your cinema function.
So no concrete advice from me!
Be carefull - don't rush into buying the Sys4. Read what other members (probably) will write in the following postings or elsewhere on the forum.
Greetings MM
kai
Posts 362
kai replied on Sat, Feb 1 2014 10:20 AM
Thanks for that prob better to stick with what we have then, i have a Mac mini connected with plex and tv shows2 on it so I get all my tv shows is a nice interface plus I can browse the web as well.
Page 1 of 1 (3 items) | RSS
