Beocenter 7000 keeps shutting itself down
MitchKes
The Netherlands
Posts 2
MitchKes Posted: Sun, Feb 2 2014 3:35 PM
Hello everyone,
I recently bought a Beocenter 7000, but the device seems to shut itself down after about roughly 10-15 seconds.
It doesn't seem to matter which feature I use on the device, after the 10 to 15 seconds it says "wait" and then shuts itself down.
Does anyone have any idea how to fix this? I would really like to have this Beocenter 7000 in working order.
Kind regards,
MitchKes
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 2 2014 4:36 PM
Welcome to Beoworld !
What speakers are you using ?
Will it do the same with no speakers attached ?
MitchKes
The Netherlands
Posts 2
I tried a couple of RL35 speakers, I tried with headphones and I tried it with nothing attached. The results stayed the same
Dillen
Posts 13,191
Dillen replied on Sun, Feb 2 2014 8:25 PM
Check the idle currents against the factory specs.
Check also the amount of DC on the speaker outputs.
aymeric
Leiden
Posts 158
aymeric replied on Mon, Feb 3 2014 9:20 PM
Does the cooling run hot? The units also shut down if there is a short on the speaker output. But without speakers attached that shouldn't be a problem. unless the socket is shorted.
Page 1 of 1 (5 items) | RSS
