Hi all
Recently I have been refurbishing a BC9500 in beautiful condition, I have reattached the glass panels and fitted a new micro computer 3volt battery as CODE was displayed in top RH . this was done with a beo4 remote, during testing a fault was evident on the BALLANCE Function, the unit would start with 3/4 volume only on LH speaker when I attempted to bring ballance to center the cassette door would pulse to attempt to open about 6mm movement ! I have resolved this issue with a beolink 1000 remote, and all was fine full functioning BC 9500 for about a hour now then it switched to STBY since then no joy in getting it to stay on for any length of time in tape radio or cd I've tried the 1271 And remove power after 3 seconds any pointers please in tearing what's left of my male pattern baldness hair out!
Thanks in hope
The battery was replaced while working in an ESD-safe environment, right ?
Hi Martin, yes I was grounded to the unit
As an addition to what I have done I noticed a small degree of,local overheating on the pins of TR10 and TR11 on PCB 60. I can't understand why it was going for approx an hour then it started switching to standby again
