BeoSound 3000 to BeoVision 11 ?
Peter Pan
Posts 2,088
Peter Pan Posted: Sat, Feb 8 2014 5:18 PM
Hallo   Idea
BeoSound 3000 - Powerlink OUT to BeoVision 11 -
9 Pin Mini DIN IN - for Radio/ CD playback.
Is this connected correctly ???
/ Peter Pan
DoubleU
Posts 562
DoubleU replied on Sat, Feb 8 2014 6:04 PM
The 9 pin mini DIN is also for CVBS and RGB video. On a regular scart, CVBS is pin 20, so I don’t think pin 2/4/6 on the 9pin mini DIN, will match the pin-numbers of a scart.
Maybe it’s better to use pin 1 and 4 from the PL-connector and use the AUX-port of the 3000 for a fixed output and let the BV11 take care of the volume.
Peter Pan
Posts 2,088
@ DoubleU
Can we find the right connection, then you do not have a NL/ ML converter.
It can work with SCART adapter, and it's only sound we want.
DoubleU
Posts 562
DoubleU replied on Sat, Feb 8 2014 8:26 PM
Why don't you cut the 9pins<> scart adapter in half. Strip all the wires from the end where the female scart is. And use a multimeter to find out which colors pin 2/4/6 from the scart-end are.
Millemissen
Flensborg, Denmark
Posts 14,680
And how would you control both systems?
tompa
Posts 64
tompa replied on Sat, Feb 8 2014 8:43 PM
The right pin for audio in mini-din is:
Left in pin 7
Right in pin 9
Gnd pin 8
Peter Pan
Posts 2,088
Peter Pan replied on Sat, Feb 8 2014 11:00 PM
Here the safe solution.
Thanks for answers tompa.  Yes - thumbs up
/ Peter Pan
Peter Pan
Posts 2,088
Peter Pan replied on Sun, Feb 9 2014 10:12 AM
@ Millemissen
An additional Beo4 can be re-coded, to only to operate the Audio Master.
Read on "permanent link" 13 April 2012 - HERE
http://translate.google.com/
Other Beo4 opportunities, or option opportunities. Write your idea
/ Peter Pan.
Page 1 of 1 (8 items) | RSS
