Masterlink connection via cat5/6 patch panel
This post has 3 Replies | 0 Followers
tonkapc
Posts 2
tonkapc Posted: Sun, Feb 9 2014 12:39 PM
I am moving house and planning the new installation of my sound system. I LOTS of masterlink cable which I have had for a while and would like to use it. I have installed an Ethernet network in the house - cat 5e for data. I was thinking of adding a separate patch panel in the cabinet to connect all the masterlink cables together. It would be a star system with all the cables coming back to the central hub. None of the items will be too far away so the cable runs will only be 30-50 meters max. The equipment I am installing is:
3200
3 x 2000
1 x active box with 4000's
1 x passive box
1 x PC link
appreciate advice - will the patch panel solution work? Do I need to add a switch?
tony
mjmedlo
Posts 922
mjmedlo replied on Mon, Feb 10 2014 3:55 PM
Are you in the United States?
Where?
tonkapc
Posts 2
tonkapc replied on Mon, Feb 10 2014 4:03 PM
I'm in the UK
mjmedlo
Posts 922
mjmedlo replied on Tue, Feb 11 2014 3:20 AM
The masterlink distribution box should work perfect. All items connected are done so in parallel so it is just like having once constant run.
I have 4 in my home now.
2 Netlink distribution and 2 masterlink.
Essentially I have 2 Star rooms (one supports 3 passive sand a beomaster 5) the other all supper televisions and link rooms.
The punch down for connection at the termination end is very simple.
Good luck!!!
Page 1 of 1 (4 items) | RSS
