I recently had to reset my Beoplay 32 from factory settings. I have a laptop, Virgin + Box and Apple TV connected and all is working well except for one minor problem.
When i press DTV which is the button I have assigned to the V+ box the tv turns on but the box does not. I need to press 'go' to turn the box on. Prior to this the box came on when I pressed DTV.
I have the correct PUC downloaded, IR blaster is set to off when tv is in standby mode.
it's a minor irritation but I'd appreciate any advice to help me fix it
Many thanks
I did exactly that and it's still doing the same :-(
the normal Virgin V+ HD Bx
