Beogram 6002 motor noise
This post has 6 Replies | 2 Followers
aymeric
Leiden
Posts 158
aymeric Posted: Wed, Feb 12 2014 8:43 PM
HI all
I have aquired a beogram 6002 but the motor is making a sort of clicking noise while rotating. It does rotate good though.
The noise is also there when i turn the motor by hand, so i don't think it has anything to do with old caps.The motor can only turn to one direction, when i try gently to turn it the wrong side it is stuck there. is that normal?
Does anybody know if this is fixable or do i need a new motor?
If needed, i can record it.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Feb 12 2014 8:46 PM
The clicking sound usually comes from a deformed commutator and/or worn or even broken brushes inside the motor.
A replacement motor will almost certainly be the only way.
aymeric
Leiden
Posts 158
aymeric replied on Wed, Feb 12 2014 8:48 PM
Martin,
I was afraid of that :(
Do you have a spare motor for sale? Or is it the same motor i have in my beogram 1700?
Dillen
Posts 13,191
Dillen replied on Wed, Feb 12 2014 9:01 PM
Sadly, no and no.
aymeric
Leiden
Posts 158
aymeric replied on Wed, Feb 12 2014 9:06 PM
No problem. if anybody else has a spare one please contact me :)
jenku
Posts 13
jenku replied on Wed, Jan 30 2019 9:36 AM
Hej aymeric
I just read about Your problem with the platter motor.
I can't help You but You can help me!
I also have a problem with the platter motor, but a different one.
All the four wires are broken off and I have no clue where I have to solder them back.
I therefore ask if You would be so kind as to send me a picture of the soldering side of the motor PCB with all four wires attached.
Hope to hear from You.
regards
jenku
aymeric
Leiden
Posts 158
aymeric replied on Wed, Jan 30 2019 10:02 AM
i'm sorry i don't have a clue how it's soldered, it's a long time ago and i don't have that equipment anymore
Page 1 of 1 (7 items) | RSS
