I've been racking my brains about this for months and can not come up with a solution. Although I love this system I find it very limiting. All I want to do is change my beolab 6000 speakers for a pair of beolab 15 or something similar in walk speaker as I'm now living in a smaller apartment. Now I notice that the beolab 15 uses a beolab 1 amplifer for power, and that the input sockets are RJ45 for connections. What I want to know is it possible to to connect the beosound 5 encore using the powerlink with a powerlink to RJ45 adaptor cable?
if this isnt possible anyone have any ideas how I could connect beolabs 15 to the BS5E? Or similar in wall speakers?
thks
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Sure - that is no problem.
You can easily buy the (adapter) cables at your local B&O or from Steve at Sounds Heavenly.
You van also buy a powerlink to rj45 cable at the b&o shop.
i have the encore with beolab's 18 with a cable 1 powerlink to 2 rj45 .
works fine
