Bluetooth upgrade for beosound 9000
This post has 21 Replies | 0 Followers
Posted: Sat, Feb 15 2014 6:40 PM
Hi guys I just found this bluetooth kit for a besound 9000, has anyone used this?, are they any good?
http://www.ebay.co.uk/itm/Bluetooth-receiver-for-Bang-Olufsen-BEOSOUND-9000-iPod-iPhone-Samsung-AIR-PLAY-/201033999106?_trksid=p2054897.l4276
or should i not waste my money?
Thanks in advance
AdiS
Posts 170
AdiS replied on Sat, Feb 15 2014 6:54 PM
so this is in my opinion nothing special. you can even use another bluetooth kit like a logitech wireless kit or same from belkin.
look here: http://www.blink.com.kw/product-detail/logitech-wireless-speaker-adapter-for-bluetooth-devices-smartphones-tablets-notebooks.html
this is what the kit in the ebay auction does. nothing more and nothing less.
regards, Adrian
replied on Sat, Feb 15 2014 7:03 PM
Have you any experience with either of those, or which one to reccomend?
replied on Sat, Feb 15 2014 7:04 PM
sorry about the spelling (damn iphone)
MartinW
Posts 389
MartinW replied on Sat, Feb 15 2014 7:17 PM
I have tried Belkin bluetooth receivers and I thought the sound was truly awful. Airplay sounds much better. Also Bluetooth is very short range so if you were to leave the room with your bluetooth device (phone?) then the music would stop. Airplay works off wifi so the range is the same as your wifi coverage. Bluetooth 4.0 is apparently much better for music quality I have been told. Not sure how that would compare.
replied on Sat, Feb 15 2014 7:30 PM
Thanks, any chance you could give me a link to the appropriate airplay device would be great
MartinW
Posts 389
MartinW replied on Sat, Feb 15 2014 7:40 PM
Go for an Apple Airport Express.
Millemissen
Flensborg, Denmark
Posts 14,680
Years ago - so it seems - I experimented a lot with Bluetooth audio receivers for my audio system.
That stopped immidiately as I discovered the AirPort Express from Apple!
Some Bluetooth receivers are less worse than others Whistle
But the problem is, that if you don't want to go the 'iDevice/AirPlay route', there in't really an alternative to Bluetooth receivers.
My answer to your last question:
http://www.bang-olufsen.com/en/sound/sound-systems/playmaker
If you should go for the AirPort Express and you want to improve the sound quality, you should consider using a small external DAC with it - to avoid the rather poor internal one.
Greetings Millemissen
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Feb 15 2014 8:54 PM
My local dealer warned me today to be aware of the imminent demise of the Playmaker .
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Millemissen
Flensborg, Denmark
Posts 14,680
No wonder shops are closing down Crying
Did he want you to sign up for an Essence Embarrassed
Chris Townsend
Qatar
Posts 3,531
I'm laying in bed streaming music by Bluetooth to my new Bose Soundlink mini. For what it is, it's excellent. And never looses its signal either!
BeoMegaMan
Posts 601
BeoMegaMan replied on Sat, Feb 15 2014 11:42 PM
If I were the OP, I would buy the PM even though it is being discontinued. It does all that the OP is trying to do with better quality, and if you play your cards right you would get a deal on the PM that is going out. I know I would give a deal if he asked :)
Ah, you know... A little B&O here, a little there
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Feb 16 2014 7:18 AM
Tonker:
I'm laying in bed streaming music by Bluetooth to my new Bose Soundlink mini. For what it is, it's excellent. And never looses its signal either! Beovision 11-46, Beolab 14, Beovision 8-32, Beovision 3-32, Avant RF 28, Beosound 8, Beolit 12, Beocom 2, Beotime, H6 and Form 2, Beo 4's and a 6.
I had mine for a few months now and it's really an excellent quality product. Sound is impressive for the size but sometimes a little "boomy". Battery lasts ages.
It's even made in Mexico.
replied on Sun, Feb 16 2014 7:32 AM
Tonker - what type of bluetooth are you using?
Chris Townsend
Qatar
Posts 3,531
I have no idea i'm afraid. I use a mini iPad, my Nexus 5 and my wives iPhone 5S. Talk about an easy setup.
The battery lasted all of last night, and i streamed Spotify and Tunein radio to it. For it's price and considering it's size, it's easily one of the best purchases i have made in ages. I cannot recommend it enough for a bedroom/kitchen, or for travelling. I listen to a lot of talk radio(LBC/Radio Five Live etc) and it is much less boomy than the A8 or Beolit 12.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Sun, Feb 16 2014 9:08 AM
Chris Townsend:
How many wives are in your easy set- up Chris?
Graham
replied on Sun, Feb 16 2014 11:44 AM
Thanks guys, I think i have decided to go with the airport express, does anyone know if i can connect it to the beovision avant 32 RCA audio input instead of the beosound 9000  because (a) I can hide the box and cable behind the tv and  (b) I wont have to buy the DIN adapter for the bs9000 aux input.
Chris Townsend
Qatar
Posts 3,531
vikinguk:
Graham
A lot
Millemissen
Flensborg, Denmark
Posts 14,680
They all share one iPhone!
Chris Townsend
Qatar
Posts 3,531
Stops them nattering too much. Anyway, pass me another one, this ones full :-)
BeoLignage
Sweden
Posts 207
just found this one
Advance Acoustic WTX-500
google it and see for your self, it houses the "new" apt-X bluetooth standard with said CD quality
Specifikationer
Kompressionsratio:
4:1
Audioformat:
16-bitars, 44.1 kHz (CD-kvalitet)
Datarate:
352 kbps
Frekvensomfång:
10 Hz - 22 kHz
Algoritmisk fördröjning:
<1.89 ms @ Fs 48 kHz
Dynamiskt omfång:
>92 dB
Signal/Brusförhållande:
THD+N: -68.8 dB
Räckvidd:
ca 10 meter
Dimensioner:
BxHxD 10 x 45 x 60mm
can also mention that I my self use the Logitech Wireless Speaker Adapter since almost two years and find it very nice sounding. Will move on to streaming sometime, but bluetooth is still very convenient.
Millemissen
Flensborg, Denmark
Posts 14,680
Sure apt-X is the best if it comes to bluetooth, and bluetooth is "very convenient". (in small rooms)...
...but "Kompressionsratio: 4:1" and 'Datarate 352kpbs" is far from 'said CD quality".
Page 1 of 1 (22 items) | RSS
