new to vinyl beogram3404
This post has 23 Replies | 1 Follower
hulkavitch
Posts 14
hulkavitch Posted: Sun, Feb 16 2014 11:07 PM
I am new to vinyl and was talked into buying a beogram 3404 at my local shop for 300. Everything is supposed to be in ship shape with little play time on the cartridge. I hear a lot of surface noise however, even with brand new vinyls which is frustrating. I have been using a carbon fiber brush which seems to help but there is still a lot of noted crackles and pops.
I have been told that  i cant replace the stylus or upgrade the cartridge? From what I understand buying a new cartridge will cost as much as what I spent on the table.  Kind of frustrated...
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Feb 16 2014 11:14 PM
Likely to be the cartridge - where are you? You can have the cartridge retipped and this would fix it. Much cheaper than a new cartridge. Can upgrade it at the same time - which one do you have fitted? I could lend you a decent one to try but I suspect you are in the US which makes it a lot trickier!!
Peter
hulkavitch
Posts 14
hulkavitch replied on Sun, Feb 16 2014 11:31 PM
yeah I am in the US, SLC Utah. The present cat is the MMC20EN. Where, how, and what does it cost to re-tip a cart?
hulkavitch
Posts 14
hulkavitch
Posts 14
hulkavitch
Posts 14
hulkavitch replied on Sun, Feb 16 2014 11:34 PM
sorry about the multiple repeat post...i thought my computer was frozen
hulkavitch
Posts 14
hulkavitch replied on Mon, Feb 17 2014 12:36 AM
hold up a sec though...did you say you can upgrade the cartridge? what others are avail for this model?
Christian Christensen
Stockholm
Posts 512
a  bad stylus can  be identified by a YouTube video as long you don't play so loud that the audio on the video recording distorts  and record is new
My re-capped M75 are my precious diamonds.
hulkavitch
Posts 14
can you explain this a little more?
hulkavitch
Posts 14
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Mon, Feb 17 2014 6:19 PM
Make a recording of the turntable playing a new LP, being careful not to have the volume too loud as to cause distortion. Then upload your recording to youtube in high quality. post a link here and we'll be able to tell you if the problem you have is a worn stylus/ faulty cartridge.
Lee
Lee
Posts 734
Lee replied on Mon, Feb 17 2014 6:27 PM
Also make sure you've got the tracking weight set correctly. The mmc20en should track at 1.2/1.3 grams. As the cart is getting on you'd be better tracking at the higher weight, maybe even 1.4/1.5g
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Mon, Feb 17 2014 6:39 PM
hulkavitch:
There's Axel in Germany and Soundsmith in the US.  I have not used Axel but the folks here sing his praises daily.
I have an MMC3000 that was retipped by Soundsmith with the $150 option.  It is currently mounted on a BG3404.  (I have a second BG3404 with an original MMC20EN.  I also have one of Soundsmith's SMMC20ENs on a BG4002.)  The retipped 3000 is a fantastic cartridge.
By the way, you are using a preamplifier in your setup, right?
hulkavitch
Posts 14
That is an awesome idea. I will get on that today.
hulkavitch
Posts 14
Im not sure what the tracking weight is set to I attached a photo.  I have a yamaha aventage RX-A3010 with Mirage MX 2.1 speakers. The receiver has a phono input. .
Lee
Posts 734
Lee replied on Mon, Feb 17 2014 10:17 PM
Looking at that picture your tracking weight is set very wrong. To set it correctly you need to firstly zero balance the tonearm first. To do this turn the weight at the back until the tonearm floats as if weightless. Once you've done that turn the dial with the numbers to zero while ensuring that the weight doesn't turn. Once it's at zero turn the weight until the dial shows 1.3g. That should fix it. Nice Speakers btw. I love the tone of mirage's.
Lee
Lee
Posts 734
Lee replied on Mon, Feb 17 2014 10:38 PM
Have a look at the image attached. That should explain how to set the stylus pressure better.
Lee
hulkavitch
Posts 14
hulkavitch replied on Mon, Feb 17 2014 11:56 PM
I went through this process and if I set the dial less than 2 the tone arm skates off the record. Did I do something wrong?
Lee
Posts 734
Lee replied on Tue, Feb 18 2014 12:27 AM
The measurements on the counterweight ie 0-9 are in 1/10 of a gram incraments. You have to set it at zero and then turn it one full turn back to zero and then on to 5 to get 1.5g (which is the weight id set it at) if that makes sense.
hulkavitch
Posts 14
good God in heaven....i did not know that. makes sense, thanks for your patience with a such a fool!
Sounds much better...still a few pops and clicks, in process of uploading a video now.
hulkavitch
Posts 14
new album video.
http://youtu.be/2UxV8AJFL0s
Lee
Posts 734
Lee replied on Tue, Feb 18 2014 1:11 AM
Your always going to get the odd pop and crackle with vinyl... That's just the nature of the beast.
Just watched the video and although it's hard to tell with a mic recording, it sounds right to me. Nice and clear on the vocals and no sibilance.
Is there anyway you could connect the line out on your amp to your computer to get a direct recording?
hulkavitch
Posts 14
yeah i was thinking the same thing but havent figured it out yet. It actualy sounds much better. Thanks for all of your help. You guys are awesome.
Lee
Posts 734
Lee replied on Tue, Feb 18 2014 1:20 AM
Glad to be of service. I've listened to the video a couple of times and I'm sure it's as it should be. Enjoy your new B&O turntable.... Happy spinning :-)
Lee
Page 1 of 1 (24 items) | RSS
