Beogram 7000 motor noise normal?
Michael
Atlanta
Posts 98
Michael Posted: Tue, Feb 25 2014 2:25 PM
I'm just hoping to determine if the motor noise from my first BeoGram is normal.  It doesn't bother me that much as it's not very loud (especially with music playing) but I certainly don't want to carry on using it daily if this might be indicating a problem that needs to be addressed.  I have Benny Amina nearby for repairs but don't want to bother him (or the Beogram's transport) for something trivial.
What say you?  Normal mechanical noise or something needing adjusting?
LINK:
http://vimeo.com/87573492
MediaBobNY
Greenwich Village, NYC
Posts 1,106
No, that isn't normal and if I recall correctly it's caused by dry motor bearings.  The motor will need service or replacement.  Hopefully Dillen will read this - he'd know for sure.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 25 2014 4:40 PM
Could be worn brushes but sounds to me more like a deformed commutator.
Live with it as long as it runs (which could be a long time, actually) or replace the motor.
Søren Mexico
Mexico City
Posts 6,411
Is the belt original, or did you change it, a too short belt can cause noises too.
Michael
Atlanta
Posts 98
Michael replied on Tue, Feb 25 2014 11:12 PM
It was changed but unfortunately that does not appear to be the issue.  I think Martin may have nailed it after a little closer examination.  I guess I need to figure if its worth the service right now to change.   Thanks to everyone for taking the time to watch and give feedback.
Michael
Page 1 of 1 (5 items) | RSS
