Unfortunately, my Beovision MX4000 has decided to misbehave, is there anyone local to Cornwall who can have a look at this? My nearest B&O centre is Exeter which is quite a distance away.
Problem is that the beovision is stuck in standby mode, occasionally it will try to start up, but cannot generate a stable picture and the tube fails forcing the beovision into standby. I'm guessing that it's a power supply failure causing this, but I don't work on TVs so am unable to fix this problem. Any ideas?
