I need to find the service manual for the Beovision 7-40 MK I but I can't.
Anyone know where I can find it?
Cheers,
It doesn't excist as pdf, unless Peter scanned the paper version.
But it isn't on site.
What seems to be the problem?
When I start up everything works fine, but after a while it starts to make strange sounds (crackles) and parts of the image gets noisy.
I guess that it might has something to do with the PSU.
There is a service manual for Beovision 7-40 MK1 in pdf format
BeoVision 7 -40 Type 935x Service Manual English
Type 935x
Service Manual
English
When I look under Service manual I can only find it for MK II and VI.
Afaik it contains only wiring diagrams in the mk1 diagrams.
So measuring at componentlevel will be some kind of guessing apart from checking solderjoints and (SMD)capacitors.
