Timer programming dissapeared ?
This post has 1 Reply | 0 Followers
JONNIE
Posts 52
JONNIE Posted: Fri, Mar 14 2014 7:52 AM
Hi I have a beo6 22 and I have noticed now when I press menu on my beo4 the timer option as dissapeared off the Mune list on the screen I used to use the tv as a alarm and it would turn on and off at a desired time but now this has dissapeared!does anyone know what may be problem ??
stefan
200 miles from Struer
Posts 2,920
stefan replied on Fri, Mar 14 2014 4:13 PM
Don`t know really what the problem is, but maybe worth to check two things:
1- What V.OPTION is your BV6 set to? Should be a master option, V.OPT 1 or 2.
If it`s in link option for using it as a link TV, you can only set Timer on/off.
2- I`d check the Masterlink module in the service menu.
Afair you can "see" ML available or not available.
If Masterlink is not available, the module may be faulty or dead.
In this case, timer programming is not possible, and you won`t see any timer menu.
Hope this helps....(?)
Stefan
Page 1 of 1 (2 items) | RSS
