BV 11 surround sound
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Fri, Mar 14 2014 6:57 PM
Are the 4 speakers and beolab plugged into a bv11  separately in the same way as an Avant ?
Trying to plan the wiring in advance of getting a bv11.
Millemissen
Flensborg, Denmark
Posts 14,680
I would say: yes - but you will need PowerLink cables with RJ-plugs (or adapter cables).
The setup of the speakers is a bit different - with much more possibilities.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Mar 14 2014 11:10 PM
If you are using BeoLab14 only the sub connects to the BeoVision 11, all of the satellite speakers connect to the sub.
For all other powerlink loudspeakers they connect to the BeoVision 11 with RJ45 powerlink cables.
Opman
valve1
Posts 1,502
valve1 replied on Sat, Mar 15 2014 6:27 AM
Opman:
So far I am planning to use a BL2, so will I have to run all my speakers from that ?
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Mar 15 2014 6:52 AM
All your speakers are connected to the TV
Page 1 of 1 (5 items) | RSS
