Bv1 wake up
This post has 3 Replies | 2 Followers
mjmedlo
Posts 922
mjmedlo Posted: Sat, Mar 15 2014 12:58 PM
Mates
I have added a bv1/ml/nl converter to my large Ml network.
I use an mlgw for control via iDevice.
I can't get the bv1 to 'wake' from an mlgw command.
It responds when it is turned on, but will not initiate turning itself on with only a gateway command.
Any thoughts?
BeoMegaMan
Posts 601
Turn on the wake on LAN setting. I think there is also a mlgw setting in the device menu. Power saving needs to be off as well.
Ah, you know... A little B&O here, a little there
Hermann_
Posts 52
Hermann_ replied on Sun, Mar 16 2014 10:23 AM
Same problem with BV11. I have already disabled all power save modes and enabled wol.
BeoMegaMan
Posts 601
Hermann_:
Make certain you have enabled your quick start timers and also set the IP address of the tv. You'll be good to go then.
Page 1 of 1 (4 items) | RSS
