Beocords
This post has 9 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Sun, Mar 16 2014 7:07 PM
Any idea why one belt mechs(used in later models like center9000...) stops winding? I have couple of them and cant find what is wrong with them?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 16 2014 8:00 PM
What are the exact symptoms (No reaction / Slipping belt / Starts but stops again after 2 seconds or ...) ?
Orava
Finland
Posts 991
Orava replied on Mon, Mar 17 2014 6:53 AM
well it tries to wind but it is like motor doesnt get enough power, so it stops. Belt is ok, no slipping, everything is cleaned, lubricated and moves freely... I haven't measure voltage or current consumption of motor yet. I dont think that it can be on electronics because another mech is (in one past case) ok with it.
Orava
Finland
Posts 991
Orava replied on Mon, Mar 17 2014 4:31 PM
reaches about 4V@60mA, a little unaccurate because I have only one analog (fast) meter...
Orava
Finland
Posts 991
Orava replied on Tue, Mar 18 2014 6:55 AM
with 9V battery motor runs nicely... hal?
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Have you lubricated the tape drive spindles??
Regards Graham
Orava
Finland
Posts 991
Orava replied on Tue, Mar 18 2014 9:45 AM
yup, whole machine
Orava
Finland
Posts 991
Orava replied on Tue, Mar 18 2014 4:18 PM
Hal's were ok, but it looks like capstain rolls do not let loose one bit when winding is pressed.
They should, shouldn't they??
Orava
Finland
Posts 991
Orava replied on Wed, Mar 19 2014 5:40 PM
Yep, just checked one functioning mechanics, it do loose roll when winding.
These two dont. Why? Microswithc somewhere?
Orava
Finland
Posts 991
Orava replied on Thu, Mar 20 2014 3:20 PM
Put fiúnctioning mech in center. And yes windings were ok.
Sequence is following: play headbridge moves fully in, press wind, heads move out and halfway in, winding.
Now, these other two does not move one bit when pressing wind. What is matter with them????? Play is ok.
Altouhg it is purely mechancal? No logic or so to go wrong?
Page 1 of 1 (10 items) | RSS
