Does anyone have idea how I can play my PC through to my beosystem 2? please.
Thanks Pete.
Hi Pete and welome to beoworld.
Can you explain in a little more detail what you are wishing to achieve? is this just for audio, or do you want video from the PC too? and if so do you just want to play media files or do you want to be able to use the TV screen as a monitor for your PC?
There are a number of options, direct cable connection, beoport (formerly beolink PC2), or one of any number of set top boxes which supports streaming audio and/or video over the network from you PC - it really depends on what you want to achieve.
Kind Regards,
Martin.
Using the VGA Input?
Ralf
PS: Welcome to the Forum.
The VGA input is only on the mk3 present.
