B&O Iphone 5 case suitable for iPhone 5S?
Rivenflush
Gothenburg
Posts 333
Rivenflush Posted: Thu, Mar 20 2014 8:29 PM
does anyone know if the B&O Iphone 5 case works with the iPhone 5S?
BR
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
parasound
Sweden
Posts 69
parasound replied on Fri, Mar 21 2014 8:17 AM
Yes, they are the same size! Should be no problem :)
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Rivenflush
Gothenburg
Posts 333
Rivenflush replied on Fri, Mar 21 2014 10:26 AM
Ok, I have heard that it could be something with the placement/size of the camera/flash.
You do not happen to have this combo?
parasound
Sweden
Posts 69
parasound replied on Fri, Mar 21 2014 5:30 PM
Yes, it will work perfect!
The flash is a little bigger on ip5s, but it don`t do any difference on your case.
All ip5 case are compatible with ip5s, says on apple.com
Page 1 of 1 (4 items) | RSS
