Where is the IR located on BeoCom 6000?
This post has 3 Replies | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Sun, Mar 23 2014 3:05 PM
Just curious; but where is the infrared emittor located on the BeoCom 6000 Mk1 and Mk2? Asking since I assumed that the two black dots onthe top of the BC6000 Mk1 was the IR sender; but where is it then located on the Mk2 handset? On the Mk2 there is the contact for the headset.
MediaBobNY
Greenwich Village, NYC
Posts 1,106
edit:  you're undoubtedly referring to communication w/ B&O a/v prods.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sun, Mar 23 2014 7:38 PM
Correct.
MediaBobNY
Posts 1,106
Point your digital camera at it while activating the volume control.  The red IR light from the emitter should be visible
Page 1 of 1 (4 items) | RSS
