Beosound 5 Encore not displaying high-resolution cover art
This post has 11 Replies | 2 Followers
WilliamLuckman
Posts 5
WilliamLuckman Posted: Wed, Mar 26 2014 12:50 PM
(First post, please be gentle)
I've recently bought a used Beosound 5 Encore, and paired it with Beolab 6000 speakers.  I have ripped the CDs to FLAC files and am streaming over a Windows 7 network from a Western Digital NAS.  I am very happy with the sound and general usability, but have an unresolved problem with cover art - despite associating high resolution cover image files via file attributes - all I am getting on screen are heavily pixelated low res images.  Accessing the exact same FLAC files via a 1.5 TB USB drive sees the Beosound use the high definition files.
Any bright ideas gratefully received.....
Millemissen
Flensborg, Denmark
Posts 14,680
Your server is sending downsized thumbnails to the Enore - which (DLNA) server are you using?
WilliamLuckman
Posts 5
(Double post)
WilliamLuckman
Posts 5
MM - thanks for the response.  From what I can see from the WD MyCloud control panel / googling, the DLNA is WD's proprietary one.
WilliamLuckman
Posts 5
(Triple post)
Millemissen
Flensborg, Denmark
Posts 14,680
Have a look in the interface of the WD MyCkoud - as far as I remember it has a Twonky server installed (?).
Be sure that is updated to the latest possible version.
WilliamLuckman
Posts 5
I've installed another DLNA server and bypassed the WD NAS completely.  It is working, even if it means using the drive I bought to back up the NAS and the NAS as the back up.  I'll do some digging and see if there's a way of changing the NAS's software without turning it into a brick.  Meanwhile, thanks for your help.
Edoardo
San Marino
Posts 163
Edoardo replied on Fri, Apr 18 2014 6:25 PM
I Just can tell you what the B&O dealer told me when I bought the BM5:
B&O recommends to store cover images with resolution up to 500x500 pixels. If you have images with higher resolution, you need to reduce it by using a graphic software.
koning
holland
Posts 4,220
koning replied on Fri, Apr 18 2014 7:11 PM
edo69:
Not true.
higher resolution also possible.
Edoardo
San Marino
Posts 163
Edoardo replied on Mon, Apr 21 2014 12:47 PM
did you ever tried to command the Beosound 5 with a tablet (as ipad)? there you will see the time that the device need to charge the covers.......
dirk
Kapellen
Posts 26
dirk replied on Tue, May 13 2014 4:18 PM
I had the same problems. The reason is that in your musicmaps there are mini-coverart jpg files wich has been created by windows mediaplayer.
You can't see them because they are hidden, so first you have to change the settings of the windows-map so that allso the hidden files are vissible.
Then you can delete them all, the problem is that mediaplayer will put them back automaticly..you can try to disable this in the settings of mediaplayer. I have disabeld the windows mediaplayer because i use vlc-mediaplayer ( works better then wmplayer).
Then it's best you enbed all the high quality coverart in the numbers , so not as a loose file, ( i use mp3tag for that.
If you do all thes things your problem will be solved.
I had the same problems and i still have the problem that coverart is only possible for a complete album and not for a title...I would like to a coverart for each number ( since i have a lot off compilation-albums with different artists...This works fine with all mediaplayers ..but not with a BS5.
I have send a message to B&O and they have responded that coverart is only possible for a album..not a number..or perhaps you have a sollution for that?
Greetings...Dirk
Barry Santini
New York
Posts 543
Bliss music tagger will embed the cvr art size of your choice to any album, track or number.
Use media monkey or mp3 tag to find unwanted cvr art jpegs and remove them.
Easy breezy. My BM 5 shows all.
B
Page 1 of 1 (12 items) | RSS
