Troubleshooting CD5500 ideas please
This post has 11 Replies | 0 Followers
bishbosh12
Posts 30
bishbosh12 Posted: Thu, Mar 27 2014 7:16 PM
I bought a CD5500 which has stopped working, actually it was a wee bit intermittent from the off. Basically, I heard it play when I bought it, we then travelled home and it didn't work, but after a short while it started to work. I then moved it in the living room and it's stopped working again.
Now when I say it doesn't work, I mean it powers up, CDs load, the display shows 'track' but that would be it. So, I've changed the capacitors bought from Dillen, but that hasn't worked so where do I go from here.
I can't help but think it might be a physical problem, maybe loose connection, crack or something.... any ideas would be great....
Cheers,
Tony
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Can we assume you've cleaned the laser lens - either via the use off a lens cleaning CD or by taking it apart and using a Q-Tip dampened with isopropyl alcohol?
bishbosh12
Posts 30
Ahem :embarrassed:, I have thought about that but because it has worked I haven't done that. I don't have the CD thing, can you explain how to take it apart??
MediaBobNY
Posts 1,106
Let's see if I remember.   Loosen (don't remove) the two screws on either side in the back and slide up the two small brackets that secure the top to the bottom base.  Then tighten the screws just enough to hold the two brackets in the 'up' position.   Then slide the top back slightly by moving it toward the back of the deck.  Then lift off.
bishbosh12
Posts 30
LOL, I thought you meant take the laser apart. I'll give the lens a wipe and see what happens.
Silly question, should it play with the cover off?
MediaBobNY
Posts 1,106
Yes.
bishbosh12
Posts 30
Cheers. MediaBob
bishbosh12
Posts 30
Ok, gave the lens a wee clean but still have a problem.
Just wondering if there is a way of determining a physical problem with the circuit board? I do have a multimeter so can measure voltage, are there any easy points I can measure?
Tony
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Mar 27 2014 10:32 PM
More than 90% of the faults to these decks are caused by bad capacitors on the servo board and you already
replaced those.
First check your work. Caps properly soldered?
Correct values and polarities?
No circuit board copper traces damaged?
Check the seating of the ribbon cable from the laser block to the servo board.
It has to be locked in correctly in the socket.
Check also for cracked solder joints to the main circuit board, particularly in the power supply and voltage
regulator areas.
Some board versions have a large connector along the left edge that is prone to crack its solder joints.
bishbosh12
Posts 30
Caps are good values, came from yourself ;-) Soldering seems ok, but will triple check.
I take it, when you say 'left edge' of the board, that's when I'm looking at it in it's normal position i.e. component side down?
tony
Dillen
Posts 13,191
Dillen replied on Fri, Mar 28 2014 8:30 AM
Yes.
And when I said correct values, I meant correct values in correct positions on the board.
bishbosh12
Posts 30
Hello, me again,
I've for looked cracked tracks but can't see any.... are there any points on the circuit boards I can test with a multimeter to see if there is anything obviously wrong? Better still , does anyone of somewhere that repairs them? Thank, Tony
Page 1 of 1 (12 items) | RSS
