Doors on my beosound 3000 open automatically but very rarely close now ,i know its old unit but its still very good ,is there a quick fix to solve this problem? my buddy is building house next to me and its very dusty now and i think maybe its clogged but i dont know how to remove doors and clean and lubricate (if this is the case) thanks to anyone with the time to reply !!
If you open the doors and then disconnect the power cable, the doors should remain open allowing you to clean the tracks of dust - or at least see if they are dirty. If you really need to remove the doors, in the same position, you pull the bottom of the door and then the top of the door (take care not to scratch the CD mechanism or display).
It is possible that the cable operating the doors may need adjustment (this involves removing the back and you need the service manual for instructions on this - available to Silver and Gold members here on Beoworld). There are various door adjustments that can be made such as alignment but involve removing the back cover - all in the service manual.
Hopefully, it is just a dust issue. If you have an air compressor, you can try gently blowing dust off (this also helps keep sensors clean).
Welcome to Beoworld by the way.
Dave.
Dave Farr: If you open the doors and then disconnect the power cable, the doors should remain open allowing you to clean the tracks of dust - or at least see if they are dirty. If you really need to remove the doors, in the same position, you pull the bottom of the door and then the top of the door (take care not to scratch the CD mechanism or display).
For removing the doors, it the same procedure as described first. Open the doors, unplug, but then pull the doors on the outerside towards yourself.
Do it quickly with the appropriate amount of force. That's the correct way to do.
Thanks very much dave, have just stripped off doors and cleaned everything, its working great now!! its been on my mind now for around 4wks and im so happy its working again . again thanks.
hi do you have any idea why load door doesnt open ? its never been a problem b4 ,the only way to open now is do it manual which obviously i dont like
hi
I hope someone clever can help me
i also have a Beosound with sticky doors / they open but they will not close without help
i tried cleaning the tracks . this worked the last time
so i removed the case i cannot see any wire or gear problems
there was lots of dust which i cleaned with a compressed air can
the motor tries to runt o close the doors but something is stopping it / they can be closed by had
any ideas / see the video
thanks
Justin
Have you tried replacing the drive belt? This worked for me on a BC2300.
i took a chance and removed the band and clean it and pulleys as best i could
now it works / super
but where do i get a spare band + can you get them online
thanks again justin
I bought mine on German eBay (I used to live in Germany)
Here's one:https://www.ebay.de/itm/Riemen-Belt-f-Glass-Door-B-O-BeoSound-3000-MK2-Anlage-Glasturmechanismus-Rubber/273499549443?hash=item3fadd7ef03:g:buMAAOSw5cNYGHfB
I am not sure if forum member Dillen can supply them - maybe worth sending him a PM.
Hope you can get your BS 3000 doors working smoothly again.
The BS Ouverture/2500/300/3200 bring so much musical and magical joy, never tire of them.
