beosystem 4500
This post has 3 Replies | 0 Followers
emakup
Posts 4
emakup Posted: Mon, Mar 31 2014 8:56 AM
hi, i have beomaster 4500.
since i have left it unplugged for a long time now it says code.
i've managed to solve it with the courtesy of a friend who borrowed me her remote control.
since i don't want to bother again i would like to buy a remote control.
which models are compatible? i'd like to buy something which would work also with other products since i might buy something more from b&o in the future.
is it beo4 a good model?
thanks
Dennis
Denmark
Posts 627
Dennis replied on Mon, Mar 31 2014 9:17 AM
BeoMaster 4500 will work with Beo4 and BeoLink 1000/5000*/7000*.
BeoSystem 4500 was born with the BeoLink 1000, so that will probably be the best choice, but the Beo4 will work fine as well though it may be a bit more difficult to program the BeoMaster - 'store' has to be accessed through 'list' if I recall correctly. But in daily use you won't notice any difference.
*Two-way communication will only work if your BM is equipped with the correct software.
/Dennis
Millemissen
Flensborg, Denmark
Posts 14,680
emakup:
hi, i have beomaster 4500.....
....i'd like to buy something which would work also with other products since i might buy something more from b&o in the future.
thanks
If you want to 'buy something more' - depending on what you are going to buy - I would suggest that you go for a Beo4.
If you want to buy a BV, you'll need a Beo4 as remote anyway.
You could buy the Beo4 now, and you could later bargain a better price for the BV without the remote.
Note: if you go for a relatively new BV, you'll need the Beo4 with navi-stick (the newest) - that can be used to control the BM4500 as well.
On the other hand - if your intension is just buying the other components of the BS4500, you'll go fine with a BeoLink1000.
emakup
Posts 4
emakup replied on Mon, Mar 31 2014 4:26 PM
thanks!
i might buy a bv in the future  so i'll go for beo4!
Page 1 of 1 (4 items) | RSS
