Essence and iTunes
This post has 10 Replies | 3 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Wed, Apr 9 2014 12:46 PM
Does anyone know if iTunes is supported by Essence? I.e can Essence find my Itunes files. Guess not but would like to have that confirmed.
If only DLNA is supported, can anyone recommend some app that can make my iTunes content visible to the Essence over DLNA? My iTunes library is on a Synology NAS connected to an iMAC.
Millemissen
Flensborg, Denmark
Posts 14,680
Do I understand your question?
Just AirPlay to the Essence - should be quite easy from the iMac.
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Apr 9 2014 2:07 PM
Millemissen:
Hi MM,
I guess Hiort wants to start music from his ITunes library directly by using the 'knob' of the Essence or Beomusic app. I think this is not possible. But if he wants airplay music from the iMac to the Essence without going to his iMac, he can use Apple's Remote app to get access to his ITunes library and then airplay to Essence.
Greets
Räuber
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Räuber,
you are probably right - about wanting to starting from the 'knob'.
This is not possible.
I did not mention the Remote app, since he just mentioned the iMac!
A way 'round (if his files are MP3's!) would be to install a DLNA server on the iMac (or use the one on the Synology), and let it have access to these files.
There are even DLNA servers that can encode m4a/AAC files to wav on the fly, and send them to a DLNA renderer.
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Apr 9 2014 3:26 PM
Räuber & MM,
You are correct. I just want to click the knob, but also being able to browse the music using the new Beo app.
DoubleU
Posts 562
DoubleU replied on Wed, Apr 9 2014 6:24 PM
My first thought would be to share the same iTunes Media folder in the BeoMusic app. In your case located on you Synology. So the Essence and ITunes just share the same folder.
edit: got the question. You have lots of m4a files?
jk1002
Posts 278
jk1002 replied on Wed, Apr 9 2014 8:30 PM
I think using Airplay within Itunes on a MAC versus on an IOS device may ake a difference.
The IOS device will at some point switch the Airplay connection off if it is not in use, if you leave your Mac running it actually keeps the Airplay connection.
So you might be OK, did someone try?
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Apr 10 2014 10:48 AM
DoubleU:
I assume that the only files that the BeoMusic app can see are the ones that are shared by DLNA, right?
So the BeoMusic app will not see whats in the iTunes media folder. Correct?
I have almost all music ripped in Apple Lossless.
Amazone
Netherlands
Posts 187
Amazone replied on Thu, Apr 10 2014 2:47 PM
the Synology NAS can share the iTunes library (which is placed on that Synology) via DNLA and as a file share. That will not be the issue. An issue might be that the essence cannot decode apple lossless files. In that case you would be able to play some of your files, but not the apple lossless files. I have not been able to find any information on what codecs are supported by the essence.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Apr 10 2014 3:59 PM
Amazone:
This is what the specification says:
Supported formats on DLNA:
• MP3 (all) or VBR/CBR 32"320kbit
• WMA, both VBR/CBR 20"320kbit
 (No support for WMA Lossless)
• AAC (ISO and ADTS)"320kbit
• PCM (WAV) general + 88.2, 96, 176.4, 192 kHz
Supported formats via BeoMusic App:
• FLAC, 8-192 kHz, 16 or 24 bits, 2 channels
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Apr 13 2014 10:34 AM
Visited a dealer this thursday for a demo.
The Essence play MP3:s even if they are in the itunes library. Majority of my music is in Apple Lossless, so I will need to convert to FLAC. I actually think it will be too troublesome compared to what I gain, to get the Essence.
The "knob" was smaller than it looked from the pictures. Nice feeling in the volume wheel.
Page 1 of 1 (11 items) | RSS
