I have the subject equipment. The 7700 powers up, but does not respond to any controls. The speakers, to the best of my knowledge are in good working order. I also have the Beocenter's remote control, and all original packaging.
Could someone give me an idea of the worth of this equipment? I'd like it to go to someone who can appreciate it as much as I did when I purchased it.
How much lights up ?
The display lights up, the lights inside the turntable lid lights up. From the displays you would think it was fully functional.
When you plug in the mains, the only thing supposed to light up is the red standby dot.If anything else lights up, be that garbled or not, either the CPU reset circuit, the CPU itself or the power supply is at fault.
