Hi, Is it possible to swap a board from a Beocentre 9500 or 9300 into a Beocentre 8000 to have the powerlink option?
Your help will be appreciated
Hi.
I'm no tech guy but unlikely I would have thought. Probably more cost effective to just get a working 9500/9300. If it's the grey matt finish you like of the 8000 then maybe try to obtain an 8500? Not many around but they do crop up from time to time.
Quite major surgery I would think to convert an 8000 to what would be effectively an 8500 but anything is possible I guess. Good luck.
Graeme.
