Remote one and BV7 mk3
This post has 3 Replies | 3 Followers
Rombeek
Posts 105
Rombeek Posted: Sun, May 18 2014 9:48 AM
There seems tot be a software update needed of my BV7 mk3, in order to make it (fully?) work with a new remote one.
Can somebody explain why?
thanks
PhilLondon
London
Posts 3,637
The BeoRemote one uses a new set of codes has has a couple of keys that the bv7 does cannot handle.
You can set the BeoRemote 1 into Beo4 mode, and it should work with the BV7, but the Info and Guide keys will remain inactive.
It is unknown if B&O will issue software updates. I wouldn't count on it. The remote already having a compatibility mode.
Beoworld app with direct photo upload and emoticons.
Rombeek
Posts 105
Rombeek replied on Sun, May 18 2014 4:39 PM
I understand you say that in Beo4 mode only Info and Guide keys will not function (with a BV7 mk3)?
PhilLondon
London
Posts 3,637
Also the 3 my buttons will function like source keys that you can programme.
That's what the manual says.
Page 1 of 1 (4 items) | RSS
