Hi I've got a Beogram 5500 turntable which has delevoped a problem. It is completely unresponcive apart from the the which backlight comes on when pluged-in. It also makes the Beomaster equally unresponcive when pluged connected. Has anyone experanced this issue before?
What do you mean by plugged in? plugged into the power or the beomaster?
What does the beogram do when connected to the power only?
The very same thing no response. Only the back light comes on.
