Use of beovision as av processor?
This post has 4 Replies | 0 Followers
Ronnie
Milton Keynes, UK
Posts 110
Ronnie Posted: Fri, May 4 2012 8:17 PM
Hello there,
i have a beovision 3 which has a dead crt and isn't in the best of condition.
I am going to remove the crt part of the tv and use the base/back which contains the boards etc and close up the top with some plastic.
Is there a way to get a feed from the tv to see what would have been seen on screen ie: volume and menu settings etc on an external display (ie: the projector i will be using).
I will also use the speakers and box them to make a centre channel fed from the tv also.
Thanks in advance!
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Fri, May 4 2012 11:08 PM
KingOfSnake
Posts 162
Simplest way I know of is to replace the CRT.
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Sat, May 5 2012 7:18 PM
I have a crt i could put in it but i dont want that, i want to make it into a beosystem type av processor where all the sources and speakers can be plugged into it. as i use a projector and would like to have it setup like that.
akoro
Posts 8
akoro replied on Sat, May 5 2012 8:51 PM
BeoVision 5 with practically same chassis used to have vga output for plasma display so I would start by looking into BV5 servicemanual and figure out what needs to be changed to gain vga out.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
