Hey there, a problem maybe the fact that you're browsing through a network maybe wireless that is not very fast so you have to wait a little bit before the contents appear because i have this little problem that is caused by the router because is not a very fast one... So i have to wait for 2 or 3 secs then i can see the contents. Then i copy them. Another way is like open from your BS5 the "Service Menu" so you get in Windows Xp and from there you connect an External hdd or a usb drive and from windows you copy everything. I sincerely suggest you to use the second one because the transfer speed is higher and if you have many songs on that then is better to use that method.
I hope i helped you
bye
