Hi All,
Does anybody have a Beovox M100 Woofer for sale?Mine has a slipped magnet.
Thanks!
One of mine did that so I had it repaired - no problem since. Finding a new one will be almost impossible and the only other solution will be replacing both with different drivers which I would not recommend. Mine went to a firm in Norfolk who did a good job. They did say they would send me pictures of the process which they never did though!
Peter
Thanks i will look for a repair then :)
But perhaps i buy a pair of m100's which are in a really bad condition with good drivers so i have some spares.
Missing a driver (filler driver as Martin calls it) for my M70. If this is part of the "bad" M100 I'm interested.
Brengen & Ophalen
Leslie, i will give you a call when i'm about to kill a M100 :)
Great, not sure though if M100 has the same driver. Martin told me a P45/P50 might have the same size but with other specs. Maybe I should try these. Have 4 P50's over here but they are meant for my BM6000 quad system.
Just got a picture from the M100 driver and unfortanetely they do not match with M70.
