Hi all
I just fixed the sliding doors of my beocenter 9500 which work good now.But the unit gets way too hot in a short time.
Is there a "no load current" trimmer on this unit? Couldn't find it in the manual.Or should i look somewhere different on these units?
Is the heat coming from the amplifiers?Also with no speakers attached ?
Yes it is from the amp area (cooling fins) and without the speakers on for example "radio" the unit also get's hot.
Does it have a trimmer for that?
