Does anyone know if you are able to bring up the list of internet radio stations and control them in the Beolink app?
TIA
Jez
Ah, you know... A little B&O here, a little there
Thanks for the info. Does that mean that it could do in a future update? Is there anyway of getting feedback from internet radio to an app or to a control system such as Crestron via direct access/uPNP?
Hello, in my opinion B&O one day will update the Beolink app, including the n.radio list, the same it did with the album artworks for n. music. The problem is that B&O is not so quick to do that. Futhermore there are more improvements they could do to the BS5 through a firmware update, but they do not do.... maybe they dont believe in this product no more? It would be a pity, being the BS5 their main audio system, at the moment.....
