Location of serial numbers on Beolab 8000
This post has 7 Replies | 0 Followers
h1npw
West Bridgford, Nottingham.
Posts 1,130
h1npw Posted: Sun, Aug 31 2014 11:28 AM
Can anyone help me - are they behind the frets?
Cheers
Nigel
VANTAGE
Posts 88
VANTAGE replied on Sun, Aug 31 2014 11:38 AM
Hi Nigel,
I had BL 8000s before. I believe you find their serial no. under the panel where you connect the cables (ML and power). Press to open.
Cheers,
Vantage
Current: Beovision Eclipse 65" v1 - Beolab 50 - Beolab 28 - 2 x BS2 (GVA) - 1 x BS1 (GVA) - Beoremote Halo - H9i
Past:
Beovision MX4000 - Beovision 3-32 - Beovision 7-55
Beosound 9000 - Beosound 5 / Beomaster 5
Beolab 6000 - Beolab 8000 - Beolab 5 - Beolab 3 - Beolab 17
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Aug 31 2014 11:42 AM
No serial number there on mine, I've just looked.  Never thought of it before but the only place I can think of is under the frets.  Hopefully someone knows definitively.
Dave.
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Aug 31 2014 11:54 AM
It is on (under) the flap that turns up to reveal the connectors. It's only a sticker, so if it's gone it's gone. There may be another somewhere inside (cannot remember) but not under the fret I'm afraid.
--mika
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Aug 31 2014 3:28 PM
This picture of a parted out BL8000 seems to indicate a sticker on the cabinet under the frets:
http://www.ebay.de/itm/Bang-Olufsen-B-O-Beolab-8000-Speaker-Cabinet-Amplifier-/221537266375?pt=US_Speaker_Parts_Components&hash=item3394a66ac7
Dave.
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Aug 31 2014 3:31 PM
Looks like the generic type label, but worth checking. I believe you could see them through the fret with a torch/flashlight (keep it against the fabric).
--mika
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Yes, but there is no serial number on it!
I promise you that the serial number and the type number are on a label stuck to the reverse of the plastic flap that covers the sockets.
Press to release on Mk1's and pull the flap on Mk2's.
Then stand on your head to read!!
If not there then somebody has removed them, probably for a dubious reason.
There is a copy stuck to the inside of the cabinet during the build
Dave Farr:
Dave.
Regards Graham
h1npw
Posts 1,130
h1npw replied on Wed, Sep 3 2014 11:40 PM
Many thanks guys - under the flap they indeed are!!
Feeling particularly chuffed with myself at the moment.... Have bought a pair of white mk2 Beolab 8000s and a Beolab 2 all for just under £1400. Can't wait to get them hooked up....
Cheers
Nigel
Page 1 of 1 (8 items) | RSS
