Hello All
Does anybody have experience of the above set up?
Customer has bought A9 and despite several attempts and re-sets cannot get the Airplay icon to appear on the iPhone.
The set up goes perfectly and the white light glows on the A9 indicating that it is connected to the network.
It just seems that the router is not allowing the Airplay function to work.
I have been told that adding a Cisco access point would solve the problem but obviously that incurs further cost.
The other option is to change a setting within the Netgear router. Something to do with "I.P. isolation"?
Can anybody give me some pointers on how to get this working?
Many thanks
Opman
Hi Berlin2010
Many thanks for your swift reply. I'll try this and let you know how I get on.
Regards
Chris Townsend:Whilst talking about routers and the A9, what should I purchase? Beovision 7-55 Mk2, 2xBeovision 8-32, Avant RF 28, Beoplay A9, Beolit 12, Beocom 2, Beotime, H6, Form 2.
The customer contacted Virgin and requested an up to date router. This has been supplied and A9 works perfectly now.
Thanks for your assistance.
