Beolink Converter 1611
This post has 6 Replies | 0 Followers
julefreund
Posts 317
julefreund Posted: Fri, Sep 12 2014 11:14 PM
Hi experts,
I would like to use a Beolink Converter 1611 for the connection of a Beogram 4500  turntable to the Masterlink System.
My question is how to make a  "reset"  with the Converter 1611, because I don`t know the kind of configuration, which the last owner of the converter 1611 has used.
Thanks , julefreund
mjmedlo
Posts 922
mjmedlo replied on Sat, Sep 13 2014 2:27 AM
It connects and self configures.
Shouldn't need a reset.
julefreund
Posts 317
julefreund replied on Sun, Sep 14 2014 12:56 PM
Hi, thanks for the info.
If the 1611 configurates by itself and don`t need any special reset, why I cannot start the Beogram 4500 with the BEO4 ? I have connected the Converter with Datalink  to the Beogram and with Masterlink cable to the Masterlink system. BV7-40 on V-Opt. 2, BS 3200 with A-Opt. 0 .
Any idea ?
julefreund
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Sep 14 2014 3:28 PM
How many pins in the cable connector from the BG4500?  There should be 7 (2 extra screw in pins) for datalink.  Sometimes these have been removed or lost.
julefreund
Posts 317
There are 7 pins in the datalink cable. I used it before with my BS Ouverture and it works perfekt.  I had fully control of the Beogram with the BEO4. Now after replacement of the BS Ouverture by a BS 3200 I would like to use the Converter 1611 for remote control,  but it doesn`t work. Why ??
julefreund
BeoMegaMan
Posts 601
The BL converter doesn't relay commands, it simply allows for audio pass through. Think of it as a blind audio master with a line level input.
Ah, you know... A little B&O here, a little there
julefreund
Posts 317
That is, what I already expected. Thanks a lot to have that now finally clarified.  So I will connect the Datalink cable directly to the BS 3200 (AUX) and start the Beogram 4500 manually. The Beolink Converter 1611 is not needed for this configuration.
Regards, julefreund
Page 1 of 1 (7 items) | RSS
