LC2
This post has 1 Reply | 2 Followers
Lars E
Råå, Sweden
Posts 8
Lars E Posted: Thu, Sep 18 2014 11:42 AM
I have five pieces Beo LC2 which worked perfectly in many years . Suddenly they do not work .
There are in different rooms , but none of them work anymore with Beo4 or the touch. In this context it should be mentioned that I live in a house with very radiated ing daylight but LC2 works neither in daylight or evening light .
After a few days , all of a sudden work again. Has anyone encountered this problem and how to solve this?
jviala
Posts 2
jviala replied on Mon, Feb 20 2017 9:49 AM
Dear Lars,
few days ago (feb 9th, 2017), I pur the following post on this forum
Dear B&O users,
668/5000
Since 3 days my 3 beolight LC2 no longer work. I can only activate 2 of them by hand.The third turns on with the Beo4 and then turns off alone after 1 hour of operation. I can turn it back on again and then it goes off after about 30 minutes of operation. The most surprising is that at night it lights up alone at least twice!
I also have a LC1 beolight that only works manually (since the same day) it no longer responds to my Beo4 remote. I can not adjust the height of the light: it is only 100% or 0%.
A user posted the same type of problem in 2014. After a few days everything would have returned to order.
Have you had this kind of problem ?. I'm worried about whether everything will go well as before. Thank you
cordially
I have always the same porblem. only afteer few hours I am able to turn off two of LC2 with my Beo4. that's all. do you have any comment to telle me ? sincerely
jacques
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
