I have just had the Virgin TiVo box installed and I cannot find a way to pause the Tv using the Beo 4 remote. It was fine with the Virgin + box, just a double tap on 'Go'. Am I now stuck with having to use the Virgin remote the whole time? Grrrr! Hope someone can help! Thanks C
No, that does not work. From re-reading your previous helpful reply, I note that there is a new PUC for the TiVo box. I will get this installed. Thanks Martin! C
