best crossover frequence bv11-bl9-bl12
manitou
germany
Posts 61
manitou Posted: Sun, Sep 21 2014 3:33 PM
i am searching the best crossover frequence for my tv and the speakers.
by default it is sometimes 120mhz or 100mhz. it seems the system uses the last programmed range.
can anyone help me please.
Geoff Martin
Struer, Denmark
Posts 672
The BeoVision 11's default crossover frequency  of 120 Hz is the best choice for the combination you have. If you are only considering maximum output level, it could be higher, however, the higher in frequency you go, the more likely you are to localise the re-directed "bass".
Cheers
-geoff
manitou
germany
Posts 61
manitou replied on Mon, Sep 22 2014 11:01 AM
hi,
thanks for your answer.
i wanted to lower the crossover frequency, to make shure not to localise any redirerected bass.
ok so i will stay at 120 hz.
during my experiences i noticed that the 12.2 produce a foreign noise at 70-80 hz (speaker at about 50). we damped the wall mounts antd controlled the screws, but the 'snare' stays. now they are at the dealer for control.
grüße horst
Page 1 of 1 (3 items) | RSS
