ML Y Box?
Heribert
Vorarlberg / Austria
Posts 804
Heribert Posted: Mon, May 14 2012 7:02 PM
Dear all,
Is there a ML box existing, that has one input and two outputs? I know there is a box with 6 outputs available and I also know the normal junction box (but this would mean I need to cut my cables).
I now have a ML cable coming from my RJ45 wall socket going to a BV8. in Future this should go to a Y-Box and then into BV8 and BM1. Anything available?
Thanks,
Heribert
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Stoobietoo
Exeter, Devon, UK
Posts 692
How about one of these. Fairly expensive though Sad  (click on the picture  to the right of the ADD TO CART box)
Stoobie
Heribert
Posts 804
Heribert replied on Mon, May 14 2012 8:50 PM
Really very expansive. I thought about a Easy and cheap Solution for some 20 euro, not more. But thanks for the suggestion
Vienna
make an educated guess
Posts 1,090
Vienna replied on Mon, May 14 2012 8:51 PM
Heribert:
PL Splitter B&O Item # 3132047 can be used for PL as well as ML distribution. Price approx 15 EUR
Wiring:
RJ45 Wall socket < B&O=Tyco Cat 6 patchcable >  Splitter 3132047 < connected to 2 x B&O RJ45/ML adapter cables
Heribert
Posts 804
Heribert replied on Mon, May 14 2012 8:57 PM
Hi Vienna
Is this like the normal PL splitter, but based on RJ 45?
Thanks,
heribert
Vienna
Posts 1,090
Vienna replied on Mon, May 14 2012 9:17 PM
Heribert:
No cable adaptor - it's a small box with 3 x RJ45 sockets (approx the size of a matchbox).
Page 1 of 1 (6 items) | RSS
